View Full Version : Pagescope Data Administrator
Arteminium
06-07-2016, 04:35 AM
I'm trying to import the details of a machine using Pagescope Data Administrator, to a local file, to use as a base.
It can read the Administration, Authentication, and Address settings.
Yet, under the 'File' tab, the options to import/export are grayed out.
The machine I'm importing from is a C368, although I also have a C220 on site.
Any idea what could be causing this?
Thanks to anyone who can help
avecosat
06-07-2016, 08:23 AM
Sometimes needs to upgrade the firmware or try with a diferent version of data administrator .
peter42
06-07-2016, 05:48 PM
from the newest driver-dvd that comes with the machine.
Then i can be shure to have all correct interfaces/drivers in the database of PSDA.
If you use an 2 years old PSDA, you can read actuall bizhub series data but the software has no information how to handle it.
I don't think the current Data Administrator works with the new C368 series
peter42
06-07-2016, 09:53 PM
nope, the actual PSDA from their new DVD runs fine and let adressbook be copied from older to new mashine without having stress.
B0265
06-08-2016, 07:27 AM
Have you selected what to export (Address Book data or Authentication data)?
emujo
06-08-2016, 01:30 PM
Before you can use the import/export functions you must have an active MFP in your registered list and have pulled down the current address book. Ver4.1.33 works with the C368 (there is a newer function version for this model, 2.1 and of course you must update PSDA to work with this version). I did test this with the "Local File" and it works as expected. Emujo
wseyller
06-09-2016, 07:27 PM
Was gonna say the same thing. It is grey out until you select the item in the list you want to export.
Sent from my Nexus 6P using Tapatalk
