Bizhub C450 error code C-B003
  • kingpd@businessprints.net
    • 919
    Does anyone know what the error code C-B003 on a konica minolta bizhub c450 is for? I think it might have to do with a fax unit installation error but I'm not sure.
    Anyone know how to fix or reset it and enter service mode?
    Thanks.
    PK
  • mitchl
    • Apr 2007
    • 501
    The code is a fax board error, try resetting the board in the machine. Real simple loosen the 2 thumb screws and pull it out and re seat it. If that doesn't work go to service mode, hit the utility key then select detail on the left bottom of the screen then hit.... stop-00-stop-01 Go to system 1- Initialization and select system error clear. If that doesn't get it going you might want to try reloading the firmware and/or replacing the fax board.
    • abbas.saati
      • 6
      KonicaMinolta C450 code C-FB54 ??
      • alexfixes
        • 68
        c-B003
        Thanks.
        PK
        hi there from CA, this error usally is caused when installed PWB-pci board and is giving you this erroe refers to canot send/recieve faxes. you can reset the code and power off/on should clear the faxes.by unpluging the fax line and clear all fax jobs will also fix this problem.
        good luck
        • alexfixes
          • 68
          fax baord
          hi there, you are correct, I aslo recomended that reset and clear,possibly rseting fax baord and also PWB-pci when is installed it will comes with this error.
