View Full Version : TA8000i Duplex Unit Fan Motor harness (DUFM)
habik
06-09-2016, 09:28 PM
Hi, has anyone had the opportunity to order this harness for the fan. From relay all the way to the fan. I am a bit lost what part number it is. It connects to YC8 connector on Relay board and it is is a real b*** to get out and someone lucky before me and me inclusive pulled the wires after several attepts to pull the connector with combination of super thin tweezers and levering with narrow flat screwdriver. Almost thinking I'll be better off by solder in hard wiring new 2 pin connector from a old clutch or something and have it just hanging on top of relay board.
blackcat4866
06-10-2016, 12:20 AM
Hi, has anyone had the opportunity to order this harness for the fan. From relay all the way to the fan. I am a bit lost what part number it is. It connects to YC8 connector on Relay board and it is is a real b*** to get out and someone lucky before me and me inclusive pulled the wires after several attempts to pull the connector with combination of super thin tweezers and levering with narrow flat screwdriver. Almost thinking I'll be better off by solder in hard wiring new 2 pin connector from a old clutch or something and have it just hanging on top of relay board.
I like the sound of that. I'm not a fan of pulling wiring harnesses, especially if you have good access to the end that you need to repair. =^..^=
habik
07-12-2016, 09:26 PM
http://uploads.tapatalk-cdn.com/20160712/c25b24e5f61f8573922db06de4c9c743.jpghttp://uploads.tapatalk-cdn.com/20160712/32dc3223fda8961385847c9f43dbb284.jpg
blackcat4866
07-13-2016, 12:35 AM
That will do the trick. =^..^=
