View Full Version : C6500 - paper stick to fuser
vlad_robas
06-17-2016, 10:34 AM
Hi,
Any normal paper with picture on it will stick (wrap) on fusing belt. I have tryed diferent 80gsm paper and it does the same, on harder paper ( from 100 gsm) it is ok. Fusing parts are'nt worn and they are still on the recomended life span.
What should I look for?
habik
06-17-2016, 02:49 PM
A glue.
Sorry for the pun.
Byting on bits.
Synthohol
06-17-2016, 11:03 PM
are they using OEM toner?
vlad_robas
06-18-2016, 10:14 AM
they are using KM C8000 toner
Synthohol
06-18-2016, 12:44 PM
why would someone use toner designed for another model?
i dont understand.
Simitri toner continues to evolve; from the start of production of the first Simitri toner for the Sitios 7035 in 2000, followed by the Simitri HD toner for the bizhub PRO C6500 in 2006, and in its 10th year, the Simitri HD+ (plus) toner for the bizhub PRESS C8000 in 2010.
the toner for the c8000 was designed for a lower fuser temp, this may be why it is sticking to the fusing belt, just too hot for it.
its hard to diagnose a problem when incorrect supplies are being used.
andyf424
06-20-2016, 03:11 PM
I've heard of people running c8000 toner in different machines, is it cheaper or something? Seems like you'd be opening a can of worms for no good reason. I think I'd rather see generic toners used rather than OEM designed for a different machine. I could definitely see the wrong toner causing the lighter paper to stick to the belt.
mircea
07-04-2016, 02:30 PM
Hi,
try to change fuser temperature
enter service mode and go to software sw settings
19-1
19-2
19-3 are the settings for the fuser temperature
19-1 0
19-2 1
19-3 1
is the standard setting
check if u have the same values
to lower it change it to
19-1 0
19-2 0
19-3 0
this is -20C settings
or to incrase it try
19-1 1
19-2 0
19-3 0
