Desert Rat
06-18-2016, 04:59 AM
It does this from power on. First it displays the J1051 code and shows a jam in the by pass tray.
There is no paper in the tray. 20 seconds later it shows the C-3102 code which refers to not seeing
the pressure on : off sensor PS26. The fuser motor does not turn. Turning the handle I can see
the lower roller going up and down as the knob is turned. It turns ok in the paper feed direction.
There is a gear with a few teeth missing, but it turns the belt.
Now this customer has a C6501 also. So I swapped them. The original 5500 fuser did not cause the
same codes to appear, the fuser motor turned in both direction. The lamps lite up. Then it gave a code
C3902 I think. But it was an overtemp code.
Put the 6501 fuser in the 5500 and the same codes appear.
Customer said he was just setting them up for a demo. Both worked for a day
then the 5500 started doing this code.
When I started this call I noticed the locking handle for the fuser tray had some in and out play.
Then I saw the the locking cam was broken and replaced that. I was hoping this was preventing an
interlock sw from closing. Nope.
How often does that conveyance driver board go bad? I have yet to change a board on these machines
in 5yrs.
Just as I was going to ask what else, the front door interlock came to mind.
But really what else?
DR
in 5yrs.
DR
