View Full Version : P-14 error in konica minolta bizhub c451
janinaresh
06-20-2016, 04:38 AM
33287
In my machine P-14 error appear, I change Black IU but error appear and not proper color registration. So please provide any solution seniors, thanks in advance
copier tech
06-20-2016, 07:59 AM
Looking at your post I can see the image is being repeated, looks like an ITB problem.
Take out the ITB, clean the IDC sensors & the ITB, if the problem remains replace the ITB unit.
andyf424
06-20-2016, 03:03 PM
what he said.
Millennium
06-20-2016, 06:09 PM
Out of curiosity - you stated that you replaced the black IU, so I'm guessing you ran the calibration after, right? Just throwing that out there because I've seen that fix registration issues like this before as well.
If you have the poster above is correct - ITB.
janinaresh
06-21-2016, 04:15 AM
Sir,
When I try to gradation then Red Light flashing not blue light, so I am not able to machine gradation, and also registration issues.
tehrancopy.com
06-23-2016, 10:32 PM
Try checking your Magenta IU . Blade or drum problem probably .
تهران کپی (http://www.tehrancopy.com)
asrar
07-03-2016, 04:11 PM
33287
Replace the PH Unit it might help you.
sidney
07-06-2016, 03:19 AM
This is a flat cable in the PH unit dirty, sorry for bad English...
Enviado de meu SM-G531H usando Tapatalk
sidney
07-06-2016, 03:53 AM
"Flat cable on the PH relay board"
