PS29 Level Conveyance Section Tray 3 jams
  • Pocavon
    • 30
    I have a C654 that jams after the second sheet from tray 3 only. It jams right after the second sheet passes the photo-interrupter (PS29) in the Horizontal transport assembly. ALL other trays feed fine. I want to replace that sensor but cant find a procedure to get to it. Anyone have any techniques to share on replacing that sensor?
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: PS29 Level Conveyance Section Tray 3 jams
    what is the jam code?
    Tray 3 feed unit output actuator at the gray roller shaft can have its bracket bent up by the most minuscule amount that allows the actuator to bounce mid sheet and cause false jams in that area, it wont cause a jam on a single page run.
    When the bracket is the correct shape the ps I have mentioned should not be able to change state with a sheet of paper in the feed unit - tested with tray closed and pressing down on actuator, if it does the bracket is too high.
    • Pocavon
      • 30
      If I understand you correctly, This may have nothing to do with the PS in the horizontal conveyance section. What I need to check is the actuator located on the tray 3 feed head assembly. It needs to switch from Hi to Lo on each sheet and not multiple state changes per sheet. Sorry I dont have the jam code . If this fix doesnt work , Ill be sure to get it.
      • B0265
        • Jan 2007
        • 718
        Remove tray 1 & 2 then you can get to the sensor, it's located above the horizontal conveyance section.
