ATSBMCO
07-11-2016, 01:09 PM
Hello,
I need to print an Event Log.
I've looked at the manual and it says:
3. Turn printer power on. Make sure the printer is ready.
4. Send the following PRESCRIBE command sequence from the PC to the printer.
!R!KCFG"ELOG";EXIT;
Note: To send a PRESCRIBE command sequence to the printer, use COMMAND
CENTER (the printer's embedded web) while the printer is connected to the PC via its
network interface.
A sheet of event log will be printed.
I cannot see an area on the Command center where to enter the coded command.
Also, I looked at the IClink way and I'm a bit lost there too.
Is there an easier way to do this?
Help would be appreciated.
!R!KCFG"ELOG";EXIT;
network interface.
