blank prints on ineo + 454e normal copies !
  • jakani
    • Dec 2014
    • 147
    hello,
    the issue started last week and no one is able to print anything all the prints are blank ! i connected my laptop directly with the machine still the same BLANK ,
    the copy is working just fine !
    any suggestions on the cause or how to solve this problem
    thank you very much
  • allan
    RTFM!!
    • 5459
    Re: blank prints on ineo + 454e normal copies !
    Can the machine do internal prints like the counter pages or the demo page?
    Whatever
    • jakani
      • Dec 2014
      • 147
      hello
      thanks for replying allan
      yes it do the internal prints !
      yesterday i changed the driver from PCL to Postscript and it start printing normally !
      BUT the problem with the postscript is very slow on the network ,so the machine takes a long time to recieve and print a single job !
      and there is 80 people printing on that machine
      i have to change back to PCL driver ! but i have no idea why it prints blank prints
      any suggestions would be appreciated
      thank you
      • imihm
        • Feb 2014
        • 77
        [QUOTE=jakani;525179]hello
        thank you[/QUOTE
        Hi There...
        Since the internal print tests are ok...it is just driver issue go back to pcl and see...
        • allan
          RTFM!!
          • 5459
          Try using LPR instead of RAW on the port settings.
          Could be a driver version problem.
          Did you try updating the firmware?
          Whatever
          • allan
            RTFM!!
            • 5459
            Is PCL error reporting on or off?
            Whatever
            • jakani
              • Dec 2014
              • 147
              no i didn't try updating the firmware ! i will try i hope it helps
              the machine doesn't show any error after it prints
              • jakani
                • Dec 2014
                • 147
                i updated the firmware and that solves the problem
                thank you
