View Full Version : Calibrate bizhub C6500
liondor1969
07-20-2016, 08:24 AM
Please help my with calibrate bizhub C6500
DigiMan
07-20-2016, 08:49 AM
Assuming you are a tech and the machine it self is clean inside(coronas,pgc sensor,color registration sensor etc).
1)Automatic Gamma Adjustment.
2)Reset Printer Gamma Sensor screenings besides contone and re-adjust them.
4)Automatic Gamma Adjustment.
5)Gamma Offset Adjustment Manual for all screenings besides contone.
6)Automatic Gamma Adjustment.
7)Calibrate controller with spectrometer(Most of the time its not neccessary if you are happy with the results).
Pretty much the simplest procedure.
Smircea
07-20-2016, 09:54 AM
I would recommend checking toner lvl from developer units before trying any kind of calibrations since u might make it even worst if your developer is old.
Service mode => Process adjustment => Sensor output check
Correct values are 120-130. If yours are lower or higher try to run density return mode from sensor output check.
After this you should clean your gama and color reg sensors.
After this try to run gamma adj and color reg adjustments.
After this you can try to print some test patterns for each color at 125 density and post those so we can try to help you more.
If u have es1000 calibrator you should try to calibrate it after you finish cleaning your sensors.
Best of luck.
liondor1969
07-20-2016, 11:11 AM
thanks all.. i must test this i hav a cd color profile update output profile v3f,naw i hav instal version 2,0..i must instal this version v3F ? Improve color this version ?
tx
Smircea
07-20-2016, 12:26 PM
tx
You dont have to install anything
If u have installed command workstation 4 or 5 go log with admin account and there is a calibration tool
You just have to insert your es1000 calibrator in usb and calibration tool will tell u everything you have to do.
Best of luck!
liondor1969
07-26-2016, 07:28 AM
Hallo
Today i buy a es1000 calibrator,I have 5 types of paper on my bizhub C6500.how to do calibration ? I can make color profiles for each type of paper ? I have comandworkstation 5 fiery 65C KM vers 2...please help me with some documents calibration procedure.
Synthohol
07-26-2016, 11:24 AM
perform all the adjustments DigiMan suggested above THEN...
https://youtu.be/R3rT-e069bg
liondor1969
08-11-2016, 12:30 PM
How is correct to set printing to LINE 1,2 or DOT 1,2 i don't now signification of this seatings..
thanks
