View Full Version : C6000 Wavy prints
Konicatech
07-27-2016, 04:09 PM
Hi all, I've got a c6000 that's producing wavy prints on anything under 140gsm stock. Bit stumped as to what's causing it, has anyone came across this?
Ta
Synthohol
07-27-2016, 04:21 PM
Humid paper?
If using regular 75gsm try setting tray 1 step thinner. Less heat in the fuser.
Also turn paper around landscape if you can see if the waves are less. Could be long vs short grain paper.
CopyJunkie
07-27-2016, 06:30 PM
I've had a deformed roller in the FS-612 cause a wavy paper issues on this model for me. The roller had expanded causing it to overdrive into the next set of rollers creating a wavy effect. With the finisher door open, I could see it pushing the paper up into a metal guide. Part number for the roller I replaced was 14JS45111E.
Hope that helps.
tech51
07-27-2016, 08:02 PM
The sprung loaded exit guide (can't remember it's actual name) in the fuser can cause this.
It has a coating on it that peels off over time.
Konicatech
07-27-2016, 09:17 PM
Hi guys,
Fusing separation plate are you meaning? here is a picture of what its doing - it doesn't do this with heavier stock though33664
tech51
07-27-2016, 09:43 PM
The plate does cause this, generally on lighter weight stock although I've not seen it as bad as that.
It would be worth replacing it, it only takes a couple of minutes
Konicatech
07-27-2016, 09:47 PM
Will try the plate and the one way gears in the fuser gearbox, hopefully if it doesn't cure it, it will at least improve it while I figure out what the hell is causing it
