View Full Version : C6000 Image problem HELP?
Konicatech
08-02-2016, 07:22 PM
Hi guys,
Im working on a C6000 just now and the image is not coming out as it should be. On the left hand side the image is fine but on the right hand side where it should be sort of fading out to the brown/yellow colour its almost white! the 2x sides dont match?
Its tricky for me to explain - please see picture
Any help is appreciated!33714
tulintron
08-04-2016, 02:29 PM
[QUOTE = Konicatech; 526780] Oi pessoal, estou trabalhando em um C6000 agora ea imagem não está saindo como deveria ser. No lado esquerdo da imagem é bom, mas no lado direito onde ele deve ser espécie de esbatimento da cor marrom / amarelo é quase branco! os lados 2x dont combinar? Sua complicado para mim explicar - por favor, veja a imagem ! Qualquer ajuda é apreciada [/ QUOTE]
I could not identify the problem in the picture, but can reverse cylinders and coronas to try to identify. Run Printer Gamma Offset Adj. to balance the level of gray and then calibrate the rip.
33714
tech51
08-04-2016, 07:04 PM
What do the individual half tones look like?
service mode test pattern 53.
run each colour at about level 120.
maybe one is fading out?
Smircea
08-08-2016, 12:26 PM
Hi guys,<br>
<br>
Im working on a C6000 just now and the image is not coming out as it should be. On the left hand side the image is fine but on the right hand side where it should be sort of fading out to the brown/yellow colour its almost white! the 2x sides dont match?<br>
<br>
Its tricky for me to explain - please see picture <br>
<br>
Any help is appreciated!<img src="http://www.copytechnet.com/forums/attachments/konica-minolta/33714-c6000-image-problem-help-madness-jpg" attachmentid="33714" alt="" id="vbattach_33714" class="previewthumb"><br><br>Usually when there is a problem with density diff from one edge to the other, it is either the corona(it gets dirty ..maybe your developer is near100% and it keeps throwing toner on it) or you have a problem with your dev unit. Usually when there is a problem with your dev unit(probably bk in your case) it is hard to fix it. You can spend a day and get no results. What it happens is that one of the screws that keeps the blade from dev unit still comes loose. Those screws SHOULD NEVER ME REMOVED since they come perfectly calibrated from factory. But still..sometimes they come loose and you can try to manually redo those by measuring the distance from blade to bias on the right side to perfectly match the left one.<br>Hope its the corona that gets dirty and you can just clean those .<br><br>Best of luck
