wseyller
08-11-2016, 01:32 AM
Bizhub 223 without HDD and has extra tray 3 with storage drawer and G00-D6 firmware
Copy mode is set to auto tray select.
Tray 1, 2, & 3 is enabled for auto tray selection.
Tray priority is 1 > 2 > 3.
All trays set to plain paper
Tray 1 has letter SEF. Tray 2 has legal. Tray 3 has letter LEF.
If you insert a document in the ADF in SEF orientation the copier will choose Tray 3. If you copy then it prints as it should for SEF but looks rotated 90 degrees as it prints on LEF.
Also occurs if you set the paper on the glass the same way. Also I installed a driver on my laptop and I could not get SEF paper when auto was selected and when I choose different combinations of portrait/landscape from within MS Word or selecting from the print driver.
I have tried moving the LEF paper in every tray combination but it always picks the tray where I have LEF. Also tried moving the SEF paper and replaced legal with SEF to have two SEF trays.
If I explicitly choose a SEF tray then it prints perfectly from copies or PC.
In user settings I set copier settings to factory default.
I performed data clear in Initialization menu.
I tried NVRAM reset
I reflashed firmware
At this point I'm thinking to swap out a MFPB from another machine. It is bizarre and KMBS doesn't know either.
I tried NVRAM reset
