View Full Version : Konica Minolta bizhub 25e Toner Empty - No Reset
Falcone
08-11-2016, 06:23 PM
I have encountered two situations with Konica Minolta bizhub 25e. The Toner Empty persists even after installing a new original Toner and eventually the machine stop. It does not detect the new toner at all and still Toner Empty on display.
Chip contacts are clean and good contact. Anybody had the same problems? Thank you.
Albonline
08-11-2016, 08:05 PM
have seen the drum, toner developer, system lock, and break the drive gears on these more than once. good luck
habik
08-12-2016, 12:17 AM
If memory serves me well, do these have a new toner release in service mode or is it only on the newer range?
Sent from my iDon't believe in marketing device using Tapatalk
Falcone
08-12-2016, 08:25 PM
[QUOTE=habik;527997]If memory serves me well, do these have a new toner release in service mode or is it only on the newer range?
Normally when a new toner is inserted on display it should come: New toner detected would you like to use it? yes No
The problem with these machines is that this is not displayed and so cannot reset the counter for a new toner.
Is there a way to reset it manually?
wseyller
08-16-2016, 06:10 PM
I think there are two electrical contacts on the toner cartridge that you need to short out. You can tape a paperclip to the contacts before putting toner in the machine. At least this was the case with a Muratec variant. Muratec support called it the Macgyver trick. I am not sure that works on this model and I don't really remember exactly how to do it.
habik
08-16-2016, 08:13 PM
I would not recommend shortening with anything other than fuse wire, if you go this route! I don't know the parameters of such fuse though!
Byting on bits.
MVPunisher
08-16-2016, 08:53 PM
Yea we used to use that trick with the Muratec drums. I don't recall the toner needing it though.
Falcone
08-19-2016, 10:11 AM
Thank you for your feedback.
The chip on the toner cartridge is with three contacts not two. Do you know which ones to short?
Normally fuse must be 0.08A if I recall.
habik
08-19-2016, 04:31 PM
Outer 2
Byting on bits.
Falcone
09-12-2016, 02:49 PM
Thank you for your help
Hansoon
09-13-2016, 05:07 AM
So did it work or did the logic board got atomized?
Hans
habik
09-13-2016, 07:54 AM
Hans
The leap of death!
Byting on bits.
jotunn
09-16-2016, 10:14 AM
Those machines doesn't use fuses anymore - there are chips in both toner and drum cartridges that hold copy of counter data.
So don't make any shorts, it doesn't work as you wish!
Cantechman
12-06-2018, 08:07 PM
This is an old thread but i'm having the same issue. whats is normally done to fix this? I assume you try a another new toner first? If that is the same result then what?
