Synaux
08-16-2016, 04:51 AM
Can someone define "auxiliary supply" and/or "reference value" of toner for me?
Is auxiliary supply simply the just the the sub hopper? Or does this actually put more toner in the developing section changing the T/C ratio too?
Manual states the following for TCR Toner Supply:
To adjust the set T/C level by replenishing an auxiliary supply of toner when a low ID
occurs due to a lowered T/C after large numbers of prints have been made of origi-
nals having a high image density.
These sequences are repeated up to a maximum of four times until the toner density
reaches the reference value. If the toner density is found to be higher than the refer-
ence value, only a developer agitation sequence is carried out.
