View Full Version : EFI ES-1000 Spectrophotometer
liondor1969
08-23-2016, 06:43 AM
Hallo
I buy a EFI ES-1000 Spectrophotometer to calibrate my KM C6500,I have a problem,WS not found my ES 1000,in windows 10 appears installed. I have old licensee 1.3 Fiery Color Profiler Suite but this not work wit win 10.WiFiery Color Profiler Suite si compatible with my ES 1000 + win 10 ?
Plese help
TX
ss12
08-23-2016, 08:46 PM
Have you tried using CWS to calibrate it?
peter42
08-23-2016, 09:12 PM
You have to install CWS from master installer from DVD. Then you get the ES1000 driver in your system. Dont go to subdirectory and install CWS from there. That fails in most installations.
Synthohol
08-24-2016, 12:44 AM
maybe some answers here.
liondor1969
08-24-2016, 07:15 AM
I have instal CWS on my pc,on pc i have WIN 10 this is compatible with new CWS 5.8..on this my ES 1000 not detect.I have old CWS on my Fiery control,I calibrated from there,but I want to do a color profile for Photoshop,i work only in Photoshop.When i print from Photoshop,colors is not ok,i must tray export PDF with color profile CMYK FOGRA39 i hop this is ok or better i must create my picture profile,please help my with same recommendation :-)
TX
Mick01
08-30-2016, 03:07 AM
Hi,
If you read the PDF that Synthahol attached you will find that the license for the software is linked to a specific spectro device. Your software would most likely have been licensed using another device and will not work with the ES1000 you have just purchased.
I am a bit confused as to why you need a specific profile to use to get accurate color out of Photoshop? Have you tried exporting one of the "standard" output profiles that come with the EFI controller? Are you trying to embedd this profile in your files you prepare in Photoshop or using it as a "working space" for soft proofing?
liondor1969
08-30-2016, 06:43 AM
Hi,
Hi
i ned this spectometer to calibrate my C6500, i tray al profil from C6500,but the perfect color ghet with profile calibrate on paper type use.I calibrate c6500 direct from fairy,naw is ok.Is ok to export from photoshop RGB to fairy,than fairy to convert this on CMYK ?
tx
liondor1969
09-08-2016, 07:19 AM
Hallo..please
I need
Fiery Color Profiler Suite (http://www.efi.com/products/fiery-servers-and-software/fiery-workflow-suite/fiery-color-profiler-suite/download/) 4.6 - 4.7 :-) to work with EFI ES1000 + win 10
TX
Synthohol
09-08-2016, 01:53 PM
Activate a Color Profiler Suite license
The downloaded Color Profiler Suite license file must be on the computer’s desktop for activation. To activate the
license on that computer, you must connect the correct spectrophotometer. If no spectrophotometer is connected,
the Demo mode message appears.
If your computer has no Internet access, you must copy the license file to the desktop of the computer that has Color
Profiler Suite installed.
1 Connect the licensed spectrophotometer to the computer.
2 Do one of the following:
• In the Color Profiler Suite main window, click Help > Activate License.
• Click Activate License in the Dongle Not Licensed window.
liondor1969
11-18-2016, 08:55 AM
I have efi color profiler suite 1.5.9 with efi ES-1000 on win 10 64bit,i want to create a color profile for tip of paper i use.I have a error wen i start the program.. please conect efi spectometer ES-1000 OR DEMO..
Plese help my wit recomandation..thanks
methogod
11-20-2016, 01:32 AM
To calibrate the printer you need Command Workstation to calibrate your monitor you need the Color profiler suite.
Cheaper to buy a good Dell monitor, never need to calibrate anymore.
liondor1969
11-20-2016, 06:15 AM
With Command Woerkstation is possible to liniarisation may C6500,i tray to create paper profile
cmykburnley
10-15-2018, 01:21 PM
Hi Guys
Wondering if you can help
Ive bought a 2nd hand ES-1000 with the profiler suite.
Im running windows 10 and command workstation.
I can get the es-1000 to communicate with cw no problem.
However the software itself i cannot. Keeps asking me to connect the spectrometer. So will only work in demo mode.
I would like to create a custom output media profile for cw
Thanks in advance
davel
10-15-2018, 01:37 PM
Get spectrometer and license from the seller otherwise bad luck.
cmykburnley
10-15-2018, 01:47 PM
Ive got the spectrometer and it came with the profiler disc.
I have the licence code on the instructions inside in the box
just doesnt let me input it anywhere
Synthohol
10-15-2018, 07:19 PM
What model cipier\IC-xxx?
Maybe you need the latest CWS downloaded from efi.com?
cmykburnley
10-15-2018, 07:22 PM
Its the latest version of cws.
CWS picks up the spectrometer no problem
Im presuming its the software colorprofiler wont work as its xp and not windows 10
jotunn
10-15-2018, 11:50 PM
You need to generate license file for Color Profiler Suite here:
EFI License Fulfillment (https://activation.efi.com/fulfillment/cps/)
You can use License Activation Code (LAC), or just your ES-1000 serial number. When your spectro is not licenced at all, you will get an error message.
Sometimes you can get 2nd hand spectro without any documents, then above website can help you check, if it's connected to CPS licence or not.
When your ES-1000 has got licence for CPS, the site will show you a _maximum_ version of Color Profiler Suite for your spectro - newer versions will not work!
Download and save your licence to your computer's desktop. The license file must be on the desktop for activation to occur.
Then, in the Color Profiler Suite main window, click Help > Activate License.
cmykburnley
10-16-2018, 10:13 AM
Hi mate
thanks for your reply
Ive clicked the link, entered the serial number and this is the error code i receive
The EFI Spectrophotometer you entered does not correlate to a licensed CPS. Please re-enter your EFI Spectrophotometer serial number or enter the License Activation Code (LAC) that came with your software.
jotunn
10-16-2018, 10:40 PM
As I remember, there should be also a sheet of paper with Licence Code (LAC) somewhere between the other documents in your package.
With licensed ES-1000 you should have in your bundle:
* Eye-One Pro Spectrophotometer and Calibration Plate with matching SN.
* USB cable
* Positioning Target
* Flat Panel holder
* Scanning White board
* Documentation
* License (LAC) - and probably serial number (I don't remember)
* Certification of Performance
* Software CD with drivers and Color Profiler Suite (version maching your license)
* Carrying Bag
However there were ES-1000 (as well as ES-2000) versions without licence for Color Profiler Suite.
Sample contents of licence file (rich version) for CPS v3.0:
INCREMENT AdvancedEditor CLRPRFLR 3.0 permanent uncounted \
HOSTID=SPECTROMETER=709679 ISSUED=27-Oct-2015 NOTICE="***** \
EAC=A-15300-52166644 *****" TS_OK SIGN="0075 3600 B659 E980 \
1AEF C587 DDA4 3300 3D47 BFA6 2BDC F6C6 0F90 1750 D4D9"
INCREMENT DeviceLink CLRPRFLR 3.0 permanent uncounted \
EAC=A-15300-52166644 *****" TS_OK SIGN="00A8 049F 0F9E D878 \
816D 99F9 2848 9B00 02C6 6296 E45E AE20 000C B6BC 242C"
INCREMENT PrinterProfiler CLRPRFLR 3.0 permanent uncounted \
EAC=A-15300-52166644 *****" TS_OK SIGN="006E B856 3F8C AE44 \
B672 A8B0 7FAF AA00 9A8C 10E2 71FF 5CF1 E317 1B48 A68B"
INCREMENT MonitorProfiler CLRPRFLR 3.8 permanent uncounted \
EAC=A-15300-52166644 *****" TS_OK SIGN="0056 EE53 CFB5 E332 \
5C00 5805 179D A600 C0D9 AFB4 92A0 6CFF DE24 D776 25CE"
INCREMENT 3DGamutViewer CLRPRFLR 3.0 permanent uncounted \
EAC=A-15300-52166644 *****" TS_OK SIGN="0014 F941 EF83 22C0 \
1FE8 F5C2 52FA 2800 E6F5 58B3 F3AD 214C 5D68 7E6C 79C7"
INCREMENT ColorVerifier CLRPRFLR 3.0 permanent uncounted \
EAC=A-15300-52166644 *****" TS_OK SIGN="00F0 BF61 3E1B 74BC \
59CD 2206 F05E 2D00 EE36 CDAC 1462 EDDA D4B5 A6A6 B3DD"
Basically ES-1000 without license is almost worthless nowdays. You can do only linearization with Command Workstation.
Or you can try to use free software like Argyll or Coloris.
methogod
10-17-2018, 01:18 AM
lets start with this...
what are you trying to do? How do you need to use it?
making profiles?
Calibrating monitors?
CWS and Onyx all recognize it internally.
cmykburnley
10-17-2018, 08:02 AM
making profiles?
Id like to make profiles with it, hence the issues
tulintron
10-25-2018, 02:07 PM
TXTo create a profile through the ES-1000, you will need a license and software.
By the CWS, just calibration, or buy CWS license
