View Full Version : Konica Minolta C353 Error C2557
mearmi
08-24-2016, 07:29 AM
Konica c353 Getting Error C2557
Replaced the IU-K
cant see the TCR values in Level History 1
all values are 0
Please advise
paulrid
08-24-2016, 09:14 AM
Try a trouble error reset in tech rep.
paul.
mearmi
08-24-2016, 09:50 AM
paul.
Have done 2 times
Tech Helpdesk
08-24-2016, 10:55 AM
If you have no TCR readings it would suggest the ICP 4 has blown on your MC Board
33944
Replaced the IU-K
all values are 0
Please advise
habik
08-24-2016, 12:39 PM
Try turning the dev gear on all IU's manually and then try Stabiliser and Background reset and then gradations in service mode. If it wont let you stabilise the image, then have a look at the ICP4 as suggested by TechHelpdesk
copier addict
08-24-2016, 01:15 PM
You actually have to run a copy to get a reading in Level History. If you just turn it on and go straight into service mode it will not show any readings.
