View Full Version : Miscellaneous Konica Minolta C280 Firmware - Error Code C152
mearmi
08-30-2016, 04:28 AM
Updated the firmware and getting Error Code C152 on Konica C280.
Do anyone can send me latest firmware GCZ-D1 etc. Please also advise about the Right File System for USB (FAT or FAT32 etc.)
Thanks a lot.
mearmi@hotmail.com
rrrohan
08-30-2016, 07:11 AM
Thanks a lot.
mearmi@hotmail.com
fat32 and use a USB2 usb drive with no more than 8GB
also if ur deprate i have a very old firmware file herer https://www.dropbox.com/s/oelmyay463e5baa/A0EDFW.tar?dl=0
but if no one else helps u out i can put on the latest one later
mearmi
08-30-2016, 07:43 AM
Thanks a lot for your reply.
I tried the same file and got C152 on the copier.
This USB was working fine but have another issue now, using 4GB USB but it gives error "This is invalid external memory"
Please advise and also send new firmware.
Many Thanks
mearmi@hotmail.com
copier tech
08-30-2016, 08:16 AM
Was the machine working OK before you updated the firmware?
Here's the latest FW, give this a try. I only use 2GB USB dives on these on C288/C552's
https://mega.nz/#!hF0Q1SDZ!z-ShY2YSa8azHS4tbbTmT7UBLdZLxZYXS8pEPDqpgaw
mearmi
08-30-2016, 08:19 AM
Yes it was working.
mearmi
08-31-2016, 04:44 AM
Thanks a lot for the FW. Tried 4 USBs. Not even one worked.
Think the problem is in MFP/Formatter Board,
Regards,
rrrohan
08-31-2016, 07:03 AM
Is it giving invalid memory error
mearmi
08-31-2016, 07:11 AM
Thanks for your reply.
Yes it is giving "This is invalid external memory"
Regards,
habik
09-01-2016, 12:02 AM
When formatting stick as FAT32 call it something.
Byting on bits.
rrrohan
09-01-2016, 02:27 AM
You can get that error if the firmware your using is incorrect. Is it GDC-D1
Sent from my SM-G900I using Tapatalk
mearmi
09-01-2016, 03:33 AM
Byting on bits.
No Luck
rrrohan
09-01-2016, 10:09 AM
if worse comes to worse i can post you a known working usb stick with firmware on it. I used it today so atleast then youd know if its bad usb or not
mearmi
09-02-2016, 01:18 AM
Thanks a lot
rrrohan
09-02-2016, 04:14 AM
Just checking you are extracking the A0ED.tar file not leaving it as a zip? Just have to ask as cant assume you familiar with KM firmware update procedures
nking58
09-02-2016, 11:31 PM
If you still havent gotten the firmware to load, I can provde a URL and credentials to allow use of internet ISW as long as the machine can get out to web on port 21.
mearmi
09-05-2016, 08:06 AM
I haven't got it.
Thanks for your help. Please advise
mearmi@hotmail.com
mearmi
09-05-2016, 08:07 AM
Have Extracted the .tar file.
Have in boxed you my address. Can you please send me a USB stick which you recently used.
Thanks and Kind Regards,
rrrohan
09-05-2016, 10:51 AM
already have sent this.
but you dont extract the tar file you put the a0ed.tar (forget the full name) as is on the root of the usb. do you want me to link you the firmware update procedure
