View Full Version : Error Code C452 Charge cleaner.
allan
08-30-2016, 05:27 PM
Any one know of a soft switch to disable the charge cleaner on a C452.
That would be really handy, can't get the gear that runs against the worm gear from the motor.
Got a new motor but no good without that gear.
mx6turbo89
08-31-2016, 12:39 AM
I ran into the same problem a few months ago and I could not find any way to disable the charger cleaning function. I don't believe one exists unless someone else can chime in and tell us otherwise. However, I was able to order the gear. You cannot?
allan
08-31-2016, 04:07 AM
Yes i can but its somewhere floating on the ocean.
Should get it in a couple of weeks.
mearmi
08-31-2016, 04:41 AM
You can disable it in:
System 1 - Charging Ch Cleaning - K Charge A/C ON/OFF - Turn it off
Regards,
mearmi
08-31-2016, 04:42 AM
Regards,
minimerlin
08-31-2016, 09:28 AM
Regards,I think the machine still does an operation of the cleaner during pre-drive start up! Even if the cleaner is turned off during print/copies.
allan
08-31-2016, 07:51 PM
Jip. No good.
