View Full Version : job log removal from fs-1135
subaro
08-30-2016, 07:23 PM
Anyone know how to remove the job log from the command center under the JOB menu. The history is there that i want to remove. there is no check box as in the address book to delete.
blackcat4866
08-30-2016, 11:43 PM
Have you tried an engine board reset? EGRE? =^..^=
subaro
08-31-2016, 12:43 AM
In the past i have tried that command and it does not work with this model. I'll give it a go once more after udating firmware ect.
JR2ALTA
08-31-2016, 01:41 AM
i suppose you could back up data and then run a sim21
subaro
08-31-2016, 04:47 PM
This machine does not have service mode u21. Some other models did not have them initially, [fs-3640 -- fs2626 ] . Later firmware update added u21 and some other adjustment modes. The job logs contain previous custome email address which should be wiped when re-deploying the machine. dealer support is my last resort, so may have to shoot them the question.
