View Full Version : Intermittent C308 machine freezing,
habik
09-07-2016, 11:35 PM
Was on G00-84 before, and SATA controller is loaded with G00-04. Tried firmware G00-E1, and machine froze after a month again. Machine is hooked to Secondary PaperCut server setup. Can login print-copy-scan release jobs. Occasionaly, display become unresponsive. Reboot usually solves it. Display has been calibrated twice.
Any thoughts are much appreciated.
mx6turbo89
09-08-2016, 12:16 AM
Try this:
Related Products:bizhub C308,bizhub C368
Related Options:
Problem
Panel is non-responsive when using Papercut.
Solution
CAUSE: Firmware requires updating.
SOLUTION: Install special firmware version GG5-54.
habik
09-08-2016, 01:00 AM
Thanks, how have I missed this version. I'll have a look for that firmware.
Sent from my iDon't believe in marketing device using Tapatalk
habik
09-08-2016, 01:06 AM
Try this:
Related Options:
Problem
Solution
Wouldn't this be fixed in the upper E1 version?
habik
09-08-2016, 01:19 AM
Havent found GG5-54 :( .Looked on ftp and ssd site. Maybe region difference/access.
The closest / similar looking I found is GC5-32
mx6turbo89
09-08-2016, 03:05 AM
Here is GG5-54 if you want to try it:
https://www.dropbox.com/s/nu9238pz1x4bhu2/C308_C368_A7PU0Y0-F000-GG5-54.exe?dl=0
There's no version 32 at all in my firmware list, so there must be quite a regional difference in firmware versions.
rindraintsoa
09-08-2016, 06:54 AM
Thanks a lot for sharing
habik
09-08-2016, 07:47 AM
Thank you, will try that on next visit.
habik
09-08-2016, 08:31 AM
Just FYI
E1 fixes these:
1,When amount-of-money-shortage User performs copy, the MFP displays a job history confirmation screen and then it freezes until system auto reset.
2,When performing Scan to Email, the operation panel freezes without completing the E-mail transmission.
3,When sending a specific PCL file, the data lamp keeps on blinking without printing.
2 and 3 may relate to me, but it happened again.
wseyller
09-08-2016, 04:00 PM
Had the same issue with C308s. I had also used the GC5-54 because in one case the would stop working if someone did a self association and reboot would fix it but this firmware permanently fixed that but not the issue where the display locks up randomly. Also our demo unit at the office would lock up.
What version of Papercut is being used. Try upgrading to latest release as this seems to help this series I have seen so far.
Sent from my Nexus 6P using Tapatalk
habik
09-08-2016, 06:53 PM
All I found in info is related to SafeQ enviornment. Not sure if Papercut can be categorized the same way Ysoft. It may for open API beat the same way. GC3-54 may be solution, although still puzzled why G00-E1 hasn't taken care of things at first. Though MR are grouped solutions from previous versions firmwares.
