View Full Version : FS 1035 dead
Raymann
09-11-2016, 01:39 AM
Just got this machine I know nothing except the fuser ohms out good but there is no hint of life. Any other experience with this machine going dead? Thanks Ray
blackcat4866
09-11-2016, 02:15 AM
How about the output voltages on the power supply? =^..^=
tech28
09-11-2016, 02:21 AM
Left side, remove cover, will see connectors to power supply, there is 1 connector that comes loose, that one goes under machine to main board make sure things are plugged in correctly. Even if no work has been done by the power supply area, that one plug barely is on and can come loose enough to give you a dead machine.
subaro
09-11-2016, 05:18 AM
In the machines i worked on with this problem, it was either the low voltage power supply or the engine-mainboard combo.
Raymann
09-12-2016, 09:45 PM
well I have 17 volts where the 24 volt fan plugs in to..
