View Full Version : Fiery Pro80 v3.0a update error
joaodaffonsojr
09-12-2016, 06:01 PM
hi !
I'm trying to install fiery updates but this error is not let me do it.
any ideas ?
thanks !
3409834097
Albonline
09-12-2016, 06:06 PM
hi !
any ideas ?
thanks !
3409834097
updates are version specific, are you tring to cross platforms?
joaodaffonsojr
09-12-2016, 06:23 PM
No.
This is a webremote for my KM c6500.
Albonline
09-12-2016, 07:01 PM
you misunderstand 3.0 and 3.0a are different. if you loaded 3.0 the 3.0a patches will not work.
joaodaffonsojr
09-13-2016, 08:46 PM
ok
I understood that they are different.
Problem is that it doesn't load ANY patches.
Problem is to find updates.
Fiery try to connect to look for patches but gives this error.
redhotrob
09-13-2016, 11:16 PM
Try using the updater that is done in the web browser, and use Internet Explorer. EFI mentioned something in the latest Tech Ticker about updates for those older controllers not working, and I think the recommendation is to use ie.
Synthohol
09-14-2016, 12:13 AM
what is the error code, the pics are so small and unreadable.
can you get on the internet? are the dns and gateway settings correct?
joaodaffonsojr
09-14-2016, 08:14 PM
3411534116
here goes another screen print.
ip address and dns
jotunn
09-16-2016, 10:59 AM
First of all, for successful update you need properly set Time Zone, current date and time - those controllers are little bit old and usually got weak mainboard batteries, so I'm using additional tool for automatic time setting: NetTime (http://nettime.sourceforge.net)
The second thing is, that controllers after software reinstallation have outdated SSL certificates, so they cannot connect with update servers (Error 10) to update those certificates - so you need to get and manually install patch FIT101063085.exe that contain current certificates.
Log into your controller through remote desktop, from the controller go to website: http://liveupdate.efi.com/WebUpdater/default.aspx?uv=004&sid=bad4942515853714db4cda2dce48491eEF778075.PPD - find, downlad and install above patch. Then reboot your controller, and try to run update, now should work.
Synthohol
09-16-2016, 02:01 PM
ftp.efi.com
if prompted:
user name: customer
password: cu$Tom3r
find FIT101063085 (ftp://ftp.efi.com/FIT101063085/)
enjoy and good luck!
jotunn
09-16-2016, 02:45 PM
ftp.efi.com
if prompted:
user name: customer
password: cu$Tom3r
For me it never worked, I can see only directory structure, can enter any of them, but there are no files inside (from my point of view).
Synthohol
09-16-2016, 04:48 PM
x; "> </Problem
Unable to perform a Fiery® update. System Updates Error... "Error no. 10"
Solution
CAUSE: SSL Certificate has expired.
Problem Solution
Related Products:IC-303,IC-305,IC-408
Related Options:
Detail Detail (http://onyxweb.mykonicaminolta.com/KB/search/Detail/KBA01104104)
1 of 2 9/16/2016 11:37 AM
© 2016 - Konica Minolta Business Solutions U.S.A., Inc.
SOLUTION: Install attached patch 1-1CO771.
1. Install this patch locally.
2. Download and place it on to a USB Jump Drive and insert to the Fiery®.
3. The install takes approximately 1 second.
4. Perform the Fiery® updates.
5. Reboot controller.
Notes:
a. Use this patch if you get this problem only.
jotunn
09-16-2016, 04:58 PM
https://liveupdate.efi.com/grad/14330/FIT101063085.exe
methogod
09-16-2016, 05:33 PM
Had a clean install of 3.0A installed this patch, still getting error 10.
thanks,
Synthohol
09-16-2016, 05:45 PM
which patch? the one i posted from konica or the FIT patch from EFI?
methogod
09-16-2016, 06:30 PM
Tried Both... going to completely restart the computer.... But did that with the 1st one, now trying with the 2nd.
joaodaffonsojr
09-16-2016, 08:02 PM
GUYS !!!!
YOU ROCK !!!!
It worked !
just after install the pacthes appears a system notification from System Updates !
THANK YOU VERY MUCH !
x; "> </Problem
Solution
Problem Solution
Related Options:
Notes:
