View Full Version : +368
CrapAimer
09-27-2016, 01:27 PM
hI
Having trouble upgrading the firmware on a +368, keeps coming up this function is not available anyone came across this before, tried formatting the stick and putting it back on but still the same
Thanks George
emujo
09-27-2016, 01:52 PM
It sounds like you are not pressing the stop key at power up with the USB stick inserted into front port( should see a small black dot while MFP boots to firmware up mode). You would get this message if you inserted a USB stick while the MFP was still prepping the user box/scan modes. Emujo
CrapAimer
09-27-2016, 01:54 PM
Got the wee black dot ?? weird one
mo0651
09-27-2016, 11:05 PM
Are you leaving the front door open??:cool:
Woxner
09-28-2016, 01:58 AM
front door does not need to be open . make sure the folder is Fw001 leave all the files in this folder after it is unzipped. try a smaller usb. biggest i have used on these is 16 gb
rindraintsoa
09-28-2016, 12:46 PM
Hello all,
we have also the same problem, if anyone can help it will be great.
HuronMan
09-28-2016, 09:54 PM
I had to flash one of these things to get rid of the b003's, a couple of weeks ago. I tried 3 different drives. A 2G and 2 16G's. I went and bought a new Sandisk 16G and it finally worked. I dunno.
rindraintsoa
10-03-2016, 02:19 PM
hi all,
I have tried diferent sticks but with no result. I found always the black dot in the right corner, and the machine is not responding like it is making an infinite loop. Anybody have a suggestion?
