View Full Version : Minolta Fuser 4049512 vs. 4049522
Can anybody tell me what the difference between this two fuser-version is? I found a lot of informations. Some claim that both will work with the Bizhub C450. Others say that the "12-version" is only for the Bizhub C350. Additionally the "12-version" is not deliverable anymore (except ebay), but the "22-version" everywhere. So what is the real difference, and can I use both in my C450? Both should be 230V, …
mx6turbo89
10-01-2016, 04:02 PM
The parts book from KM shows the 4049512 as fitting the C350 only, and the 4049522 is for the C450 only.
You are right. But there are so many sources telling that the 4049512 can be used in the C450 as well. I do not think they all tell lies, ... here are a few examples:
https://www.amazon.de/Konica-Minolta-Fusing-4049-512-4049512/dp/B002KGYKA8
http://www.alfatec.co.uk/copier-printer-fax-supplies/konica-minolta-4049-512-fusing-unit-bizhub-c350-c351-c450-original.html
Konica Minolta Toner - Minolta Toner - Konica Bizhub - Bizhub C350 - Konica Minolta 4049512 Fuser Unit (http://www.konicaminoltatoner.co.uk/product_info.php?products_id=3722)
So I am wondering if not both fusers are the exact same, just with different part numbers for different machines?
But I would like to verify this, before ordering one ;)
EarthKmTech
10-02-2016, 12:08 AM
i recall it being a simple modification to make a c450 fuser go into a c350 or vise versa i can't remember, something stops it seating properly. but electrically it worked once modded. I didn't do it, some one else did.
habik
10-02-2016, 08:45 PM
EarthKmTech is right. There is a stupid metal circle plate that covers a hole on one of the fusers. Get a flatblade a just rip it off. Its at the back of the fuser.
Sent from my iDon't believe in marketing device using Tapatalk
hotfuser
10-03-2016, 10:07 AM
remove little metal circle disc off the rear of the fuser so the seating pin fits. Easy fix
