konica 7050 F28-2
  • mdm7266
    • Dec 2007
    • 99
    konica 7050 F28-2
    Hello there. my problem on konica 7050 is Intermittent code F28-2. Transfer problem. I already replaced the Transfer/Separation Assembly but still same code appears. Could this be a problem on HV2 assembly which is under the registration assy? i'm planning to replace the HV2 assembly. but not sure if its really the problem. cause i have to buy it, i must be sure on what to replace thats why i'm seeking your opinion based on experience on field.
    thanks in advance
  • deep
    • Jun 2008
    • 206
    You should also check/replace the plastic block (The one that make contact with the T/S Assembly) near at the far end of the convey unit.
    If problem still cannot be solved, then try HV2.
    Kenny
