View Full Version : Miscellaneous Konica Minolta C353 - Replace The Waste Toner Box
mearmi
10-12-2016, 07:06 AM
Konica Minolta C353 - Replace The Waste Toner Box Error
Black toner Hopper was full. Vacuumed it 2-3 times. Replaced the toner with original one as the old toner was from Katun.
Copier worked for 3-4 days. Again getting same weird noise and error message for the waste toner box.
Advise Please
Thanks and Regards,
Luther
10-12-2016, 12:49 PM
replace the waste toner box.
https://www.youtube.com/watch?v=RAX6CUXnhuY
mo0651
10-12-2016, 02:41 PM
Hey Luth, It's a C353 !!:cool:
mo0651
10-12-2016, 02:43 PM
We have had to clean and replace some of those bottle sensors. But it goes by resistance inside the toner bottle. You said you cleaned it out. So it is a used bottle. Maybe a new one will last longer.
mearmi
10-12-2016, 05:15 PM
Thanks for your reply.
Replaced the waste toner box. Black hopper unit is full
emujo
10-12-2016, 09:23 PM
The noise may be coming from the waste toner augers, if so you may just want to replace the MFP as this is a bitch to fix. Not sure why you keep mentioning the black hopper is full. If you're going to re use the bottle (not recommended) you have to really clean that little window (over flow) if this is dusted with toner it may not regard as being replaced. If your black hopper is "compacted" with toner you have another issue. Emujo
habik
10-12-2016, 11:28 PM
I bother just get some clicks on YT haha :D good luck with your machine. You can try and vacuume out the augers from the top whilst banging on them from the transfer belt side and replace worn/broken gears.. x2.
Best of luck!
https://www.youtube.com/watch?v=L9FNwmMhxZ4
https://www.youtube.com/watch?v=qeTjSW-Styk
JR2ALTA
10-13-2016, 03:29 AM
Fatal flaw. Bring in the sales team.
mx6turbo89
10-13-2016, 04:13 AM
The C253 and C353 are due to hit end of life next June anyway, so it's best to get it out of there now. That's going to be quite a time-consuming repair.
Trigger
10-20-2016, 04:01 PM
am i the only one confussed with this thread? surely its a case of trying a new waste box and be done with?
hotfuser
10-20-2016, 05:24 PM
No the noise and waste toner is the give away. it is the rear waste pipe get baked toner blocking the pipe which cause the auger gear to jump causing the waste box full message appear.
it is a real pig.
http://www.copytechnet.com/forums/konica-minolta/29564-c253-loud-banging-noise.html?highlight=taminol
mx6turbo89
10-20-2016, 06:34 PM
This model has a toner waste auger system that has a tendency to clog up. Normally not a big deal in other models, but it's buried within this machine and requires a lot of disassembly to access it. The symptoms of a clogged waste toner auger in this model is a grinding noise and a 'replace toner waste box' notification.
edit: Sorry Hotfuser, didn't see that you'd already answered this.
