View Full Version : Miscellaneous 1060L Installation question
DigiMan
10-15-2016, 08:00 AM
Goodmorning everyone!
Kinda silly question actually but im going to install a 1060L in a couple of days and i was going through the new installation manual.
I noticed when you are done with the screws etc and you turn the switch on it says touch startup then package adjustment and after a while
Color adjustment(Which is described in the SM).Question is what exactly is covered in the "package adjustment" and what must you do for the color adjustment?In the color adjustment in the service manual it covers like 100 topics,what exactly must be adjusted?
Thank you in advance!
Synthohol
10-15-2016, 01:45 PM
pkg adj does everything, do it at install and every PM.
Package adjustment
Following adjustment items are performed automatically in the order.
• Toner Density Sensor Initial Adjustment
• Blade Setting Mode Adjustment
• Belt Line Speed Adjustment (Not performed)
• Gamma Adjustment
• Color Registration Adjustment
• Density Balance Adjustment (Not performed)
(2) Usage
Use the overall adjustment when you want to perform various settings at once after the installation.
(3) Procedure
1. "Service Mode Menu screen"
Press [18 Startup Setting].
2. "Startup Setting Menu screen"
Press [01 Package Adjustment].
3. "Package Adjustment menu screen"
Press [Start].
4. When the message "Adjustment after unit replacement is completed." is displayed, press "Exit".
DigiMan
10-19-2016, 05:16 PM
Package adjustment
• Gamma Adjustment
(2) Usage
(3) Procedure
Press [Start].
Thanks synth and sorry for the very late response! :D
