View Full Version : Can't print on Bizhub C300— "Replenish Paper" error message...
Snurtle
10-16-2016, 08:36 PM
But there is plenty of paper in the tray.
What is going on? Is there a way to bypass or reset?
Thanks for the help,
Snurtle
Synthohol
10-16-2016, 08:47 PM
make sure its not calling for a different media type. if i send a print job set to thick1 by mistake and its only set to plain ill get the same message. and vice versa...
blackcat4866
10-16-2016, 09:03 PM
Like he said. Read the screen! What paper Size? What paper Type? Both have to match or you'll get a "Load Paper to the Bypass... " message. This goes for any machine. =^..^=
Snurtle
10-16-2016, 09:53 PM
The media type is the same. Not doing an unusual print job...plain old 8.5x11.
Here's a screenshot:
Snurtle
10-16-2016, 10:18 PM
FWIW, I have cleaned all the rollers, checked for jams, done a power reset, loaded fresh paper in the drawer..... I'm getting the out of paper message from my laptop as well.
blackcat4866
10-16-2016, 10:53 PM
When you change to Copy Mode does it also say "Load Paper Tray #1"? Tray #1 may be unable to lift ... maybe because there is paper behind the tray? Or you may have a lift motor problem, or a lift sensor problem, but check behind the paper tray first. =^..^=
Snurtle
10-16-2016, 11:20 PM
Great ideas, thank you!
There was no paper behind the tray.
I just tried to copy something... wound up with this error:
Malfunction detected. Please call your technical Representative.
C-8103
Woxner
10-16-2016, 11:52 PM
Error
C8103,jam code 660x
Root Cause
DF-608, C8103 (C-8103) or possibly jam code 660x.
Workaround/Fix
PROBABLE CAUSES:
1. Binding or failed lift motor (M7).
Check for binding in the lift motor assembly (p/n 9J07 R707 00) and replace it if necessary.
2. The lift plate is not producing strong enough pressure.
Install mylar shims (p/n A01H 5615 00 and A01H 5616 01) under the lift plate to increase pressure. Multiple sheets can be used. See attached Bulletin Number 6278 for location and details.
blackcat4866
10-17-2016, 12:03 AM
Like Woxner says this is a secondary (unrelated) issue. Turn off the MFP, disconnect the document feeder, and continue to diagnose the paper tray. Once you figure that out, you can proceed with the C-8103 in the document feeder. =^..^=
