View Full Version : sd card ahthentication failed in mp9000
vargue
10-16-2016, 10:22 PM
hi guys i had this message i installed a new printer/scanner sd card original.with known that machine worked before without that function. is upgrade is a clue.
adween shaari
10-17-2016, 12:00 AM
Have u confirmed that sd card okay or not?
slimslob
10-17-2016, 01:20 AM
Did you install the entire Printer/Scanner kit or just the SD card and the key tops. Printer/Scanner requires the installation of additional memory that is included in the kit.
vargue
10-17-2016, 02:27 AM
additional dimm already placed in sluts. 2 ram already exist .just sd card
slimslob
10-17-2016, 06:09 AM
Printer/Scanner requires 2 128MB DIMM and 1 256MB DIMM in addition to the memory already existing on the machine.
34456
vargue
10-21-2016, 05:11 PM
today i upgrade firmware and the same issue still appeared .i swapped sd from another machine. the message gone .but printer and scanner application not appeared .i did 5985 and all being correct. what's the point . all dimm ram 256 and 2 ram 128 in mother board.:confused:
Counsel
10-21-2016, 06:40 PM
Does the SD card have a "lock" on it, I haven't had to install one but just curious if it is in locked position if that would matter.
vargue
10-21-2016, 07:21 PM
it's on unlock position .
slimslob
10-22-2016, 12:17 AM
Is that the total RAM on the board or just those added for the Printer/scanner function. When you added the RAM did yu do so as shown in the service manual? The added memory has to go in specific locations as shown in the service manual.
vargue
10-30-2016, 10:45 PM
thank yo guys lane board is not exist.:mad:
