View Full Version : pro c754 error s1 & s2
ash_572
10-17-2016, 08:13 PM
i have a konica pro c754 with a message on the command workstation giving me an error s1 and s2.
everything seems to be working perfectly fine.
i have cleaned the optics even though it was clean anyway.
the manual states ccd and cis gain adjustment failure.
i reset the message in service mode under warnings and a week later the message re occurs.
any help would be appreciated.
thanks
habik
10-18-2016, 10:23 PM
What firmware level have you got loaded at the moment?
ash_572
10-19-2016, 12:22 PM
I have no idea sir,
could it be the firmware?
Albonline
10-19-2016, 01:45 PM
thanks
the message is saying something wrong with scanner in the adf, not the main ccd, try looking up in there . also in trouble reset mode do the aes adjustment after you clean everything. if it returns after that you will need to trouble shoot/replace, the adf interface cable.have seen a couple that turned out to be the dual scan board on the main body or the ribbon cable that attaches it to the mfp board.
