View Full Version : Konica Minolta C364e USB NG
copierwhisper
10-25-2016, 12:47 AM
I'm trying to install the animation guide on a C364e using a USB and file that works on another C364e. The machine will not detect the USB is install from any port. Is there a way the USB ports can be disabled or does anyone have an idea why none of the USB ports will recognize the USB? AND/OR is there another way to upload the animation guide?
Woxner
10-25-2016, 12:57 AM
front usb port and service mode system two page two data install thats the only way. unless someone has disable usb from printing and scanning. try a 2 or 4 gig drive
Woxner
10-25-2016, 12:58 AM
by the way these can be turn on or off in admin mode
copierwhisper
10-25-2016, 01:13 AM
I just tried using an 8gb USB and it worked. Why the 2gb USB that worked in the other machine isn't working I have no idea, but at least I have the file loaded now...
aleksander
10-26-2016, 05:38 AM
Are you using USB 3.0?
in some device, USB 3.0 is not worked properly. Try using USB 2.0.
copier tech
10-26-2016, 08:08 AM
You need to have the correct firmware to match the animation guide.
Best solution is first install the latest firmware (currently GD2-M1) Then set the function version to the latest 7.
Now you can install the Animation guide, (Animation Guide Data Version G00-30)
34558
MDR24
10-26-2016, 09:32 AM
I'd say try to reformat the memory stick using FAT32. Found that the Konica Minolta's seem to prefer that to the default FAT.
