View Full Version : Bizhub C-25, 4FFF code...
Oystercopy
10-27-2016, 04:28 PM
This happened to my (own) machine at home, right when AT&T was "repairing" my network. Can anyone tell me, is this RE-settable? or is the only option replacement of boards?
Thanks in advance,
OC
Paskudny
11-25-2020, 07:12 PM
And how did you solve the problem? I have the same..
Oystercopy
11-25-2020, 08:25 PM
I never did, I just trashed the machine...
Synthohol
11-25-2020, 09:39 PM
4FFF
Controller connect error
• MFP board/1 (MFPB/1) to MFP board/2 (MFPB/2) connec
tion failure
4FFF: Controller connect error
18.4.30
18.4.31
C002: RAM error at startup (standard memory)
C003: RAM error at startup (expanded memory)
Relevant electrical parts
Step
Action
WIRING DIAGRAM
Control signal
Location (electri
cal component)
1
Turn OFF and ON the power switch.
2
Check the MFPB/1 connector for proper
connection and correct as necessary.
3
Check the MFPB/2 connector for proper
4
Check for proper connection between
MFPB/1 and MFPB/2 and correct as nec
essary.
5
Change MFPB/2.
6
Change MFPB/1.
best advice is to trash it.
thats coming from someone that still owns an analog EP2030.
tsbservice
11-26-2020, 05:17 PM
You know of course analog machine is way simple and sometimes reliable than fancy-schmancy new ones. If you have working consumables why not 😄
copytechman
11-26-2020, 06:30 PM
4FFF
tion failure
18.4.30
18.4.31
Step
Action
WIRING DIAGRAM
Control signal
Location (electri
cal component)
1
2
3
4
essary.
5
Change MFPB/2.
6
Change MFPB/1.
EP2030? Wow that brings back memories... EP450Z, 470Z, 1030, 1031F, and so on and so on!
Regards!
A.
