View Full Version : Printing Problem - Konica Minolta biz hub c451 (Shades)
matsan_offset@yahoo.com
10-29-2016, 01:10 PM
Hello,
I have problem with my K-M BizHub C451. Everything going ok till first 50-60 (approx.) prints but later on it start to give shades on both BW and colors.
3460334604
Also at white parts of image or empty pages it gives very light yellowish/reddish (in color prints) and greyish (in B&W prints) colors.
34601 34602
Do you have any idea of the reason?
Thanks in advance.
Synthohol
10-29-2016, 03:31 PM
in service mode, test prints, gradation pattern c/m/y/k print them out, may help isolate the problem.
10-29-2016, 05:39 PM
34605346063460734608
Flash
10-29-2016, 05:55 PM
I would say the black imaging unit is shot.
10-29-2016, 06:11 PM
So if we change this unit, will the problem be gone?
darry1322
10-29-2016, 06:50 PM
The black unit is bad. Replace that unit, do the color alignment, and gradation adjust. See what you've got from there.
Synaux
10-30-2016, 01:07 AM
Make sure to add something to the lever to push the K IU all the way in or buy the mod (there are many posts about this).
From the looks of it, the black IU is most likely spewing developer. If it is leaking dev, take it out to see if there is any developer on or around the IU (use a magnetic screwdriver to see if it clings--if it does its dev and not toner).
If this is the case you need to clean the IU cavity, as well as the Print Head and the yellow IU! When I see dev spew I personally also clean the IDC sensors and transfer belt.
Also, I am willing to bet your yellow IU is bad--destroyed by the dev.
Also:
Go in service mode > counter > life
Post the life of the IUs
(If it is spewing dev. you might also have a bad HV board.)
1FRY1
10-30-2016, 10:50 PM
Matsan
Do I take it you are a user rather than a technician ?
MFPTech
10-31-2016, 02:57 PM
This is a typical user response. You are not a tech, are you?
Sent from my SGH-I337M using Tapatalk
10-31-2016, 07:43 PM
Matsan
i am not technician, just a user:(
10-31-2016, 07:44 PM
Synaux
11-01-2016, 01:04 AM
Yea...you can try changing the IUs, but you probably need to get a tech out to fix the underlying issue.
