View Full Version : Bizhub C284 Login Error when authentication and account track are turned OFF
captainrva
11-01-2016, 07:12 PM
I have a peculiar problem that I have never run across. A customer has 20 computers and they are all the exact same. Only 1 of those computers is now having an issue printing. The jobs are deleted due to error, and the error is a login error. I checked and both Authentication and Account track are turned off so this shouldn't be happening. I have reinstalled the driver and restarted both the computer and the copier to no avail. Any help is much appreciated.
copier tech
11-01-2016, 07:34 PM
If the issue is only happening on 1 pc out of 20 it clearly is an issue with that one PC. Most likely a currupt driver even tho you reinstalled it the pc could still be using the currupt one. It could simply be the driver setting have authentication etc enabled. Also try a different version ie PCL5/5. Also run windows update on that one PC.
I'd also update the copier firmware.
blackcat4866
11-01-2016, 11:13 PM
It's also possible that there is a connection issue with the specific PC. Go to that PC and start a continuous ping to the server. You might notice very long ping times, or completely dropping out periodically. =^..^=
Synthohol
11-01-2016, 11:42 PM
wait... please explain what a log-in error has to do with printing.
log-in is for PSWC not printing. al logon error is for scanning AFAIK.
can you be more elabritive?
allan
11-02-2016, 12:39 AM
When he checks the print history on the machine it states print job "deleted due to error" detail "login error".
As if print user authentication is failing.
Got no clue as to why that will happen.
I would check things like the driver printer configuration to see if authentication or account track is manually switched on. Still makes no sense.
Or under admin i would look to see if "Print without authentication" option is available.
Had corrupt drivers do weird stuff before.
The suggestion to use a generic PCL driver is good but you loose functionality.
Would ip filtering show as an error in the printer log??
Synthohol
11-02-2016, 01:10 AM
ok, thanks for the clarification.
yeah i'd delete the drivers and start over on that PC.
not just the queue, the drivers too in>>>
34628
Mr Spock
11-02-2016, 02:52 AM
I had a wonderful IT staff that turned on the account track to monitor the print usage. Hard coded the driver so the end user would not see the popup. After some fall out with management they went back and turned account track off. They could not understand why no one could print.... The local print drivers (where they hard coded the code) was still trying to pass login info to the machine and machine was showing login error. They had to enable account track on the local pc then remove the account info then turn it off to get everyone printing again.
captainrva
11-02-2016, 09:02 PM
I got it sorted today. I turned authentication on and print without authentication at the panel, sent a print and it came through so I then turned off the authentication and now it prints normally. I appreciate all the help!
KM7155
05-31-2018, 08:15 AM
Guys, i have a c364e, it cant print when the account track is enable, it showed Login Error at the details of the deleted job.
without the account track, no issue with the printing.
i did the verify password, it succeeded.
the firmware is A5C10Y0-F000-G20-M1(00).
thanks.
KM7155
05-31-2018, 08:18 AM
thanks.
what i have done,
reformat the hard disk
clear the account track entries
reload the printer driver
try new and old version driver
try different PC to print.
pappyvonsillypants
06-08-2018, 04:48 PM
Re: Bizhub C284 Login Error when authentication and account track are turned OFF
http://www.copytechnet.com/forums/images/misc/quote_icon.png Originally Posted by KM7155 http://www.copytechnet.com/forums/images/buttons/viewpost-right.png (http://www.copytechnet.com/forums/konica-minolta/113468-bizhub-c284-login-error-when-authentication-account-track-turned-off-post607069.html#post607069)
thanks.
what i have done,
I am having the same issue my self. they had a c360 w account track and had no problems. we upgraded them to a c454e and with out account track it works.... with it it gives me a log in error... any resolution to this??
thanks.
what i have done,
Are you printing to the Fiery or the C284?
paulrid
06-08-2018, 06:45 PM
thanks.
what i have done,
did you update the driver? Old one will do basic printing but won't work with account track due to different signing?
pappyvonsillypants
06-11-2018, 02:06 PM
yes i had updated the driver to the new one. firmware is up to date as well... i m having their i.t. delete everything from server and pcs to start fresh in 10 minuetes i will update with any info. no fiery using empron controller.
B0265
06-11-2018, 02:58 PM
Make sure the correct model is selected in the configure tab of the driver.
Hi, I've had a similar problem. The problem is in the driver. I downloaded the universal drivers to solve.
To add to this...
Also make sure the function version selected in the configure tab is the same function version on the mfp. This option is not available on every model but will cause group authentication errors if the versions do not match.
pappyvonsillypants
06-20-2018, 02:17 PM
Hello by universal driver what do you mean?? i am a tech of 16 years and know my way around a machine etc... but where is that at on knoicas site? also i took my laptop and crossed over and still got a log in error, yet that lap top can print to my machine at the shop with no issues what so ever.
Hello,
is very easy! Go here: Download Centre - KONICA MINOLTA Europe (https://www.konicaminolta.eu/en/business-solutions/support/download-center.html)
After search your model and open "Drivers".
Scrolling through you will find "Universal Printer Driver". You've never seen because it's a fairly recent novelty.
39930
pappyvonsillypants
06-20-2018, 02:49 PM
I found it and will try this I appreciate it!! Vielen Dank, dass Sie ein Lebensretter sind
