View Full Version : C500 ghosting reds
Lindsay Hundley
07-18-2008, 02:24 PM
I have had a issue printing reds on this machine. Whenever I print red type, I get a ghosting affect around all of the type. It almost looks like the paper isn't absorbing all of the toner. I have tried multiple paper types and I get the same problem. Does anyone know a setting that might help eliminate this problem?
Rolandito
07-25-2008, 03:08 AM
Try to replace magenta DV a magenta image unit
random
07-25-2008, 07:18 AM
this usually happens after a developer change. Has it been serviced recently?
Lindsay Hundley
07-25-2008, 02:22 PM
yes ... within the last month both PM's were done
random
07-26-2008, 08:26 AM
Well, what can I say. You need to get some some volume on the machine and this fault will disappear. This has been fixed on c6500 by spinning the dev tank in reverse, sorry no real fix for c500. There is a vs/vp dip switch but it doesn't really make a lot of difference.
Si@danwood
08-13-2008, 06:20 PM
I wouldnt be too concerned!!!If you are getting reasonable RED reproduction AT ALL on a C500 you are doing wonders:confused: No help i know but couldnt resist:D...si
laserman06
08-14-2008, 02:34 AM
What application are you printing from? There are some settings in that can be changed. The only thing that I could find was the following:
Last Used in the Contact Center: 6/23/2004
Times Used in the Contact Center: 3
Related to Escalated Issue: No Created: 3/11/2008
Modified: 3/11/2008
Priority: Normal Products Products:
CF5001
bizhub PRO C500
8050
IP-901
Options:
None Specified Details Subject:
Red print has a halo effect when using Microsoft® Word.
Description:
Solution:
CAUSE: The output profile in the printer driver is not set correctly.
SOLUTION: Change the output profile in the driver to Swap-Coated. To do this, perform the following:
1. Select file, print.
2. Click Properties.
3. Select ColorWise.
4. Click Expert Settings.
5. Select the RGB Separation down arrow and set to Simulation.
6. Select the drop down arrow for CMYK-Simulation Profile.
7. Select the CMYK-Coated (EFI).
8. Click OK three times.
SPECIAL NOTE: Solution contribution by Mark D'Attilio, Production Print/SSD
Hope this helps.
Rob
