View Full Version : Miscellaneous Kyocera Setup Tool
Richard Knode
11-10-2016, 12:05 PM
Hi
Ive been using Netviewer to update address books and codes for a while but have noticed there is a Setup utility for exporting via 917 converting them to another model and re importing. i have version 2.1.0415 but have seen a manual for version 3 which allows saving to newer models. Our Kyocera Tech Spec has never heard anything about this utility.
Has anyone a link to download please.
Thanks for the help.
wragsdale
11-10-2016, 01:27 PM
Login to the dealer portal and browse to the printer utilities section under tech resources.
It not only supports newer models but also has a convert folder option for batch processing.
Richard Knode
11-10-2016, 01:54 PM
Many thanks for quick reply i have logged into dealer portal but still cannot find it. Im the the Europe website Service world for Firmware and tech support etc. Have you any models of printers the utility is under.
thanks again.
wragsdale
11-10-2016, 03:27 PM
Try to open this link: http://www.kdaconnect.com/dnetpub/jsp/Kyocera/ResourceDetails.jsp?rid=29192
habik
11-10-2016, 03:45 PM
You may find only the actual .pdf file.
You have to request it through registration form despite being logged in as dealer.
Bit silly, but then you'll get an link via registered email to download the aplication.
Byting on bits.
raven181
11-10-2016, 03:46 PM
Connecting to the kda site from europe returns a 404 error - if you have a copy of the setup tool can you email me a link to gary.raven@asl-group.co.uk please?
wragsdale
11-10-2016, 04:41 PM
If you have KDA credentials, try logging on first and then open that URL. I also get a 404 if I'm not logged in. I'll send you a link anyway, but see if that works.
MFPTech
11-11-2016, 10:45 AM
it's crap, doesn't work!
Sent from my SGH-I337M using Tapatalk
XaR0uLiS
11-26-2016, 07:24 AM
You can try this one:
Kyocera Net Viewer v5.5.0721
http://downloads.kyoceradocumentsolutions.com.au/Utility/Utility/KyoceraNetViewer.zip
MFPTech
11-26-2016, 01:50 PM
I meant the setup tool is crap, the links work fine. Even the Kyocera utilities that work are counter-intuitive.
bush_tech
08-02-2018, 05:42 AM
resurrecting an old thread here but does anyone have the original application/installer?
dealer portal link now 404's
JVergin
08-06-2018, 06:30 PM
Page Not Found (https://us.kdacentral.com/content/dam/kdc/kdag/downloads/technical/executables/utilities/kyoceradocumentsolutions/us/en/SetupTool_313621.zip)
Here's the link. Before clicking on the link you'll probably have to log into kdacentral and then come back to this thread and click on the link.
For the record - We love this tool! At least once we figured out how it works.
Before replacing a Kyocera with another Kyocera at a customer's office, we will grab the U917 info from their old copier and convert the Address Book, One Touch Keys, and Job Accounting to their new equipment before it even leaves our office.
Much easier than hooking both copiers up in the customer's office and transferring the info via net viewer.
Geo
08-07-2018, 12:00 AM
PLEASE
If possible can you, step by step list the procedure? For whatever reason I seem to have zero luck and T.S. is not much help.
THANKS MUCH....
darry1322
08-07-2018, 01:03 PM
From the source copier run 917 and select everything ( not just address book, etc ) to export.
Run setup tool as Admin and choose "File -> Convert" and select the folder with your exported files
Choose the model for your destination machine and save the output to a thumdrive to use for your import.
JVergin
08-07-2018, 05:57 PM
^ That's pretty much it.
What I do is this:
1) U917 export address book, job accounting, and one touch key to my usb drive
2) Plug the flash drive into my computer and move all files from the root directory to a folder called "Old files"
3) open setup tool
4) select File > Convert
5) select the "Old Files" folder on your usb drive and press OK
6) select the model of the NEW copier you're transferring the content to and press OK
7) It'll ask you where you want the files created. Select the usb drive (You'll want it in the root directory) and press OK
8) Put the usb drive in the copier and run U917
9) select import and highlight address book, job accounting, and one touch key and execute.
10) done!
darry1322
08-07-2018, 06:46 PM
What I do is this:
3) open setup tool
10) done!
That's it. I'm just too lazy to type it all out.
On step 1 we've always had to export everything to get it to work. If we just exported those 3 we couldn't convert. I haven't tried it since the early version. Maybe they fixed it?
Geo
08-08-2018, 02:17 PM
Thanks much for the step by step instructions. If this works for me , installations will be much less stressful.
Thanks Again :D
Synthohol
08-09-2018, 01:07 PM
btw, netviewer works one machine at a time as well.
i import then export. saves it as a zip file.
i rarely get to plug bot machines at the same time.
just choose save to file from the old machine and create from fil on the new one. netviewer converts just fine.
the setup tool failed me 4 times so i refuse to even try anymore.
ntbann
08-09-2018, 06:08 PM
You can download the setting from KFS then convert them for the new machine. You don't have to see both machines that way.
sparkycivic
08-09-2018, 09:11 PM
I always use the setup tool "convert" function. it does the whole batch of what's possible in one step.
first, export ALL the 917 data to USB from old copier. Certain models won't convert unless you export everything at once.
point the setup tool to the usb using the convert function, set destination model , point to a local folder for save destination, boom done!
erase the USB, and put the saved files from the local folder onto the usb.
put usb in new copier, 917 import the first four buttons ONLY(address bk, one touch, accounting, user)
extras:
-Don't use the same folder location for convert and save, because it might lead to files of the same name depending on which models you're working with.
-I always open the new address book file afterwards using the tool to verify that I converted the correct files, and that the output isn't blank.
-If your customer has altered their machine admin password, it will be carried-over to the new machine and you won't be able to setup anything further without their password. This can be remedied by flashing a stock "user" file exported from a new copier.
We are able to export via KFS (with the user's help) and do conversions/setups at our office so that new copiers are practically plug-and-play, which is helpful when many of the customers are 1-3 hours drive away!
justanotherhack
08-10-2018, 05:03 AM
It's a beautiful thing, works very nicely if you know how to use it. Only converts address books and job accounting codes though.
