View Full Version : TA 3550ci image section repeat 6x or 7x
magtech
11-29-2016, 04:43 PM
Hi every one
I have a Taskalfa 3550ci who when you copy from the glass, a section from the image repeat 6 or 7 times on the page (see attachment)
The problem is intermittent
I Updated the Firmware and replace the HDD
Did someone ever see this problem ?
thanks for you help
Geo
11-29-2016, 10:39 PM
Your example was not very clear...However, did you check/clean all the charge rollers? Also given that image is repeating, measure the distance between the marks and check the repetitive defect chart in the SM..
darry1322
11-29-2016, 11:38 PM
Look at them again. It's not repeating a mark, it's repeating whole image sections again. It looks like some serious data processing issues.
blackcat4866
11-30-2016, 12:34 AM
I had a Toshiba e Studio 306 do this ONCE. I have the samples. AFAIK it never happened again.
http://www.copytechnet.com/forums/toshiba/107924-copy-quality-if-you-can-call.html
34888
