mdm7266
07-23-2008, 09:40 AM
Hi there, my problem on this konica 7033 is that when i make a copy on
2-sided ( 1 is to 2) using the Document feeder, the other side has a deletion on one side (the other back) the page number i'm copying does not appear. When i invert or reverse the original on ADF, some text upward where missing. this happens only on the ADF 2 sided (1-2) .
the front side is ok but its back copy has deletion.
what might be the problem on this machine? Could it be the paper size program. the paper is set at 8 1/2 x 11.
Already solved the problem by mode 47-69
Thanks anyway
Thanks anyway
