View Full Version : bizhubs
big jase
07-23-2008, 11:25 AM
what information do i need in order to set up scan to email:eek:
dallas
07-23-2008, 12:18 PM
In which network environment?
Inside or externally?
At least Admin- and Device Mailadress (Admin settings) and SMTP Server Adress (Email settings).
big jase
07-23-2008, 12:23 PM
both i believe,,customer wants to send emails within building and to other places 2
dallas
07-23-2008, 12:37 PM
Certainly. I meant, where's the mailserver.
In a local domain using Exchange oder externally like gmail or something.
techSuperHero
07-23-2008, 01:39 PM
Lots of ways to do this. I would start by treating the machine like an Outlook Mail client.
You will then have to deal with host resolution, authentication, relay, and firewall issues.
You can even setup a PC with the copier's IP address on the same drop using an Outlook Express mail client. If this outlook client works, then there is no reason the copier won't. Make sure the customer's tech admin is aware of this, and if it doesn't work outlook gives you better detail of why the configuration failed.
Hope to have helped.
LBZ
Truth Be Told
07-23-2008, 07:11 PM
If the email server is off the premises, just make sure that the it accepts mail from your copier's IP address.
