View Full Version : Bizhub C203 Firmware
TechMayday
12-05-2016, 12:56 AM
I bought a used bizhub C203 and upon startup, it is stuck at the hourglass. I replaced the Ram and no change. I'd like to try reloading the firmware. I think the latest is:C203 GRG-R6 C203_A02E0Y0-F000-GRG-R6.exeI'm not a dealer... help?
ivovb
12-05-2016, 07:19 PM
I prefer mass production version A02E0Y0-F000-G20-R6. Anyway this hourglass might be HDD, PCB... Try trouble reset procedure before any expensive repair.
BR
shadow038
12-06-2016, 08:29 PM
If firmware does not work, try memory chip.
TechMayday
02-17-2017, 08:21 PM
Turns out that the memory I used was defective. Now I am able to start the printer but it sticks on error C-D010. Hard drive unformatted. The touch screen locks up and I am not able to enter the service mode to format it?
Help?
copier tech
02-17-2017, 09:43 PM
Have you tried reflashing the firmware?
scottybbb
02-17-2017, 11:28 PM
Try unhooking the hard drive and you should be able to get into service mode.
TechMayday
02-18-2017, 08:44 PM
I bought this firmware: A02E0Y0-F000-GZ1-R6 I'm using a SanDisk 256 MB CF card, I wrote the firmware using The Konica Minolta Firmware Imaging Toolkit 2_53. I Tried disconnecting the hard drive and the printer never finished starting, stuck on Konica Minolta Logo. I appreciate any ideas / help
TechMayday
02-18-2017, 09:26 PM
I tried the reset procedure and it stops at the KM logo as well.
mx6turbo89
02-19-2017, 01:42 AM
Sounds like you've got an NVRAM problem.
Here's the NVRAM Clear firmware: https://www.dropbox.com/s/8y9mgbk2wbvifrb/C203_A02E0Y0-F000-GEQ-J8%2800%29.EXE?dl=0
Here's the procedure (Read this first before starting): https://www.dropbox.com/s/7xpg17b9q4yuw93/NVRAM%20reset%20procedure%20for%20Mosel%20and%20Th ames.pdf?dl=0
TechMayday
02-19-2017, 11:39 PM
Huge thanks, making progress... I was able to follow your instructions and reset the NVRAM, now it says: "serial number needs to be entered" "Contact service representative" - dont have a rep...
The instructions say to enter service mode either I am doing something wrong, or ?
I press Utility Counter key and it beeps, I press stop and it beeps, then i press 00 stop 01 and each time it beeps but the screen does not advance.
35675
Synthohol
02-19-2017, 11:55 PM
hold down utility when booting for service mode
TechMayday
02-20-2017, 01:40 AM
Holding utility down during boot hangs on planets screen.
Swapped out main board, flashed firmware A02E0Y0-F000-GZ1-R6
and still hanging on "serial number needs to be entered" "Contact service representative"
ivovb
02-20-2017, 09:04 AM
Stop-0-0-stop-0-1 press them in same intervals of time and don't wait for beeps.
BR
TechMayday
02-20-2017, 06:57 PM
Still not working?
https://www.dropbox.com/s/se7gqoacp622xow/File%20Feb%2020%2C%2011%2001%2020%20AM.mov?dl=0
Any other ideas?
BR
ivovb
02-20-2017, 09:27 PM
Wait for warning beeps to stop (initialization is finished) and than start with U/C-S-0-0-S-0-1.
BR
TechMayday
02-20-2017, 10:40 PM
I tried several more times, still not able to enter service mode. I'm beginning to think I have another problem. Maybe Failed NVRAM or? After the beeping stops, I try entering the key combination, the screen never changes, & non of the onscreen buttons respond & about 30 seconds after the initialization beeps stop, the printer is non- responsive. No buttons respond and even turning off the power button on the display does not respond.
BR
