habik
12-06-2016, 01:17 AM
Hello all.
Have a customer 2hrs drive away with intermittent "Internal Error" issue during prints to the machine + Address Book can't be exported (this could be browser issue but, I'll be wiser when onsite.) To cure it re-boot is required or opning front door.
So far has been done:
IP Conflict has been negated
Network set to factory defaults and re-entered correct data
Driver updated to the latest ver.
To follow:
Firmware sits at D2. but re-flashing is the next step along with diferent Data Socket and port on switch + Network lead replacement
Suspecting: MFPB or HDD if above fails?
Has anyone came across this or similar issue? ANY ideas are welcome and appreciated. Cheers!!
I have a list of what could cause it, just want to get my guns ready when onsite and from what I understand it will be network related issue.
3007 http request result problem
• Internal error occurred. Or due to internal reset, process was stopped.
3016 http request result problem
CFA50 IGC control error DB error C
CFA51 IGC internal error
IEEE802.1X
36 • Internal error of the certificate verification (EAP-TLS/EAP-TTLS/PEAP).
LDAP
2266 • Internal error of the certificate verification.
E-Mail/Internet Fax
2 • An internal error occurred.
SMB Transmission
12266 • Internal error of the certificate verification.
SMTP Transmission
554 • An SMTP server error, or an internal error when sending data.
The transaction failed.
WebDAV transmission
1099 • Other internal error occurred (e.g. memory shortage).
SMB browsing
User authentication
WebDAV client
• The process is cancelled by an internal reset.
16 • An internal error occurred
To follow:
IEEE802.1X
LDAP
E-Mail/Internet Fax
SMB Transmission
SMTP Transmission
WebDAV transmission
SMB browsing
User authentication
WebDAV client
