Hi
I am having a problem with a bizhub C554e and the PCL6 driver v 5.1.3
When I click on the Obtain Device information I get "Printers cannot be connected. Check the Port Settings.......". I have tried changing all of the Obtain settings- Auto on, Auto off etc. I have tried with SNMP enabled on the Port and disabled. SNMP is on on the machine. I have tried a different Port IP that is working with another bizhub. I have matched the the Function Version (7) with the driver.
Nothing helps.
The machine has User Authentication enabled. If I set the driver option to On (MFP) manually , the username selected will verify on the driver. If I print, nothing prints out and the Job List shows Error deletion- and details show a Login error
I would be grateful for any advice
Cheers
Pat
Nothing helps.
Cheers
Pat
