View Full Version : c7000 printing photos with very high compresion
Canonier
12-08-2016, 10:54 AM
hello all i have a strange problem with a KM c7000 P
when i print photos the photo is printen with visible squares like compresion only in white ang grey colors.
it appears like squears in pattern and only on white and greys.
any ideas?34973
qbert69
12-08-2016, 03:37 PM
I see more blur than squares!....are you talking about the white dots on the right side?...I wouldn't have an answer for that! If it is a low resolution trying to be printed to a higher resolution, the fact that the dots/squares between the resolutions haven't been interpolated correctly is the key factor! If it is a low resolution "for placement only" image that you are trying to print out at a higher resolution, I highly recommend the Fred Miranda SI Pro (Stair Interpolation) action plugin for Adobe Photoshop:
Stair Interpolation PRO (SIpro) (http://www.fredmiranda.com/SI_PRO/)
It works!...I've tried it.
Good Luck!
:cool:
