View Full Version : Error Code Error code c-dc010 appearing in c654
lwals2015
12-12-2016, 06:48 PM
An error code as appeared in C654 virgin have tried to clear no change I need help
TheBlueOrleans
12-12-2016, 07:07 PM
bizhub C754/C654 I ADJUSTMENT/SETTING > 11. SERVICE MODE
(7) HDD Format
(a) Use
• To format the hard disk.
• The function proceeds in the order of physical format to logical format.
• If the hard disk is yet to be formatted, the malfunction code “C-D010” will appear. Ignore this code and continue with the formatting
procedure.
• When the hard disk is mounted.
• When the hard disk is to be initialized. (Physical format to logical format)
NOTE
• As HDD formatting deletes Movie data, Voice data, OCR dictionary data, Unicode Font data, OCR font data or PDF/A font, you
need to reinstall these data as necessary after using this function.
Woxner
12-12-2016, 10:02 PM
you should be fine just doing the logical formatt and reinstall movie data and address book if you backed it up. logical takes 5 minutes. physical takes a long time. i never do the physical
