View Full Version : Error Code Konica Minolta C284
Fuzzylogic
12-13-2016, 11:02 PM
Hello Again
This machine works fine for about 500 pages then it wont print the complete document, hangs, and needs to be rebooted. This is a continuing cycle and in the Machine Management List the error code is E301. It has firmware A1610Y0-F000-G20-70 which was supposed to fix a similar problem but now this has popped up.
Any suggestions.............
Synthohol
12-13-2016, 11:50 PM
make sure spool to HDD is on under printer settings: basic settings.
check HDD vacant space
backup all to flash drive and do a logical format. then restore settings, check vacant space again.
it shouldnt bail out like that.
did you watch the memory%? when it happens?
does it have the EK extra ram?
mx6turbo89
12-14-2016, 12:29 AM
Hello Again
That's some old firmware. Try the latest base firmware (A1610Y0-F000-G20-72). It resolves 14 separate issues of the E301 code.
dickierock
12-15-2016, 03:50 PM
I had something very similar recently with logged E301/machine hanging up. On our suppliers suggestion we replaced the firmware first,then Hdd, then the ram. This didn't work,it seemed to me it was something print/network related.
Next I updated the drivers, and finally reset network card/changed the i.p address of the machine. It seems to be fine now so far so good.
I would suggest to you to do the reverse of what I did.
