View Full Version : Bizhub 223 code 8101
jonpaul
12-22-2016, 08:50 AM
we have a biz 223 that is showing code 8101 the service manual is not very forthcoming has anyone a simple answer,thank you
copier addict
12-22-2016, 02:25 PM
Service manual is pretty detailed.
19.5.74 C8101: Before reading pressure welding alienation mechanism trouble
Relevant parts
Reading roller release motor (M3)
Reading roller release position sensor (PS12)
DF control board (DFCB)
Step Action
WIRING DIAGRAM
Control signal
Location (Electrical
component)
1 Check the connector between M3-relay
CN5-DFCB J15 for proper connection and
correct as necessary.
2 Check the connector between PS12-DFCB
J15 for proper connection and correct as
necessary.
3 Check the connector of M3 for proper drive
coupling, and correct as necessary.
4 PS12 I/O check, sensor check DFCB J15-3 (ON) DF-621 G-1
5 M3 operation check DFCB J15-4 to 5 DF-621 G-2
6 Change M3 — —
7 DFCB F8 conduction check — —
8 Change DFCB
Also check for something that may be stopping the rollers from pressing or releasing.
Hope this helps.
PS. The issue is with the DF
CraigW
12-22-2016, 03:07 PM
DF-621 ?
Likely paper left from a jam. Those feeders are very tough to make reliable from what I've seen.
copier addict
12-22-2016, 03:24 PM
DF-621 ?
These are my least liked DF.
allan
12-22-2016, 03:54 PM
Then there is a B36 DF.
The DF-621 can take a beating. Except the plastic the sun deforms it like nothing i have seen before.
CraigW
12-22-2016, 03:57 PM
If you are scanning the improved "paper present" actuator (with the magnet in it) is a must have.
mx6turbo89
12-22-2016, 11:40 PM
If you want something easy to try first, install firmware G00-D6. It addresses the C8101 issue.
