View Full Version : Electrical FK-502
hugohug
12-27-2016, 08:42 PM
Konica Minolta bizhub 361 fax sends but does not receive. Just rings on the line but never answers
Synthohol
12-27-2016, 11:09 PM
unset it in service, unplug both fax wires, boot up, let come to ready, shut down reconnect wires, boot up add fax1 as set, initialize the fax, make sure the marketing area is correct fax, reboot and try again.
all else fails try calling it from your cell and see if it even rings.
blackcat4866
12-27-2016, 11:41 PM
Surprisingly often, your customer will have no idea what their own fax phone number is. There may even be a fax on the line at that number, just not yours. Or it may just not ring ... or the ring voltage may be too low. Or there may be four faxes sharing the same line, all set to 2 rings, all vying to be the first to answer. Many possibilities. =^..^=
copyman
12-28-2016, 11:49 AM
The fax target is most likely not set to the correct country.
hugohug
12-28-2016, 05:38 PM
Did all that except for un-setting and setting How do I set the machine to hear in-coming rings? You can hear the ringing on the phone. Also, how important is it to have a 2-wire jack line plugged into the machine. It does send with no problem and you can hear dial tone when selecting off-hook Thanks
Synthohol
12-28-2016, 06:11 PM
Dial the fax number and when you hear it ringing on your cell select off hook and see if it's even the right phone number
copyman
12-28-2016, 09:53 PM
Not sure how important but I have used 4 wire cords a few times and worked ok. I mostly use what Kon/Min supplies with fax kit, which is 2 wire. There must be a reason why they only use 2 wire.
Synthohol
12-28-2016, 10:07 PM
EMI and fluorescent lights. the black and yellow act like antennae wires and can cause interference.
2 wire is the safe bet.
ive had many a call about fax issues, changed the wire and never heard from them again about the issue.
Mr Spock
12-29-2016, 12:50 AM
call the number and hit the onhook button and see if you can hear yourself on the copier speaker. If so then the pwb with the plugs need to be replaced.
If not but you hear a dial tone then the number you are dialing is incorrect. try dialing your cell from the machine and see what number shows on caller ID.
Try calling the number on caller id and see if machine answers.
