View Full Version : Miscellaneous b250 not taking paper
vamaturure
12-28-2016, 03:19 PM
hie tecs
i have a bizhub 250 which is failing to take more than 30 papers in its tray. if you put a ream of bond it will make some noise and the give a code error of c0202.
how best can i tackle the issue.
the problem is said to have started after a long day of printing abt 4k copies.
thanks in advance
copier addict
12-28-2016, 03:32 PM
Have you tried anything to fix it yet? C-0202 is a lift error.
copyrooks
12-28-2016, 03:40 PM
look for paper behind tray 1.
vamaturure
12-29-2016, 06:31 AM
notyet
vamaturure
12-29-2016, 06:32 AM
there is nothing there
REGSIS
12-31-2016, 08:55 AM
There's a motor back there with a plastic clutch that could be broken. I think that you can switch positions of motors (should be the same); remove both trays and replace lift motor from tray 1 to tray 2 and vice versa.
Now if it that drawer work OK and the other drawer produce an error - order a new lift motor.
vamaturure
01-02-2017, 08:56 AM
thanksregisitturnedouttobeahousingofthemotorhadbro kenmaybeduetoimpactcauesedewhenclosingthetray
copier addict
01-02-2017, 01:49 PM
Space bar is usually at the bottom of the keyboard in the middle. For future reference. lol:cool:
vamaturure
01-03-2017, 09:41 AM
kkkkkk it wqas not responding.
:rolleyes::rolleyes::rolleyes:
darry1322
01-03-2017, 11:58 AM
Ithappenstomefrequentlyonthissite.
It happens to me frequently on this site. I have to type in Notepad and then cut and paste into the editor pane because my spacebar doesn't work in the editor.
vamaturure
01-03-2017, 12:40 PM
that makes the two of us.
:o:o:o:o:o:o:o
