View Full Version : Miscellaneous Konica Minolta Bizhub C454e Print/Scan
mearmi
01-05-2017, 04:10 AM
Konica c454e stopped Scanning/Printing. Ethernet connector light is ON.IP settings are correct and is not pinging Please adviseThanks
Woxner
01-05-2017, 05:03 AM
use a laptop to see if it connect. use a cross over cable you can also try a network reset. possible mfp is bad
blackcat4866
01-06-2017, 12:56 AM
It may also help to hard set the network communication speed (rather than Auto). =^..^=
emujo
01-06-2017, 02:24 PM
A minor or major network change could cause this issue. NIC would show connection LEDs, but configuration no longer matches the network so you would lose communication. Could be a gateway issue, or did you move to a different ISP. Emujo
Rvale
01-11-2017, 12:15 PM
i had the same situation today, checked verything without success, my check list for such situations goes like: Config page print, ping, connect with crossover, Cable, sockets, router, Initialize, firmware, PRT Board, OACB.
But you have to check it all yourself, dont rely on anyone to clear some points for you.
Rgds.
mearmi
01-12-2017, 09:43 PM
It is pinging and printing
we didn't change ISP
client reset the settings and got this issue
Woxner
01-13-2017, 01:48 AM
what is the scan error? is this email smb or ftp
rrrohan
01-13-2017, 08:06 AM
The fact he mentions ISP obviously means he used email.
It could even be server fault. Mailbox full?
